Nov 6, 2017 10:53 AM UTC
How to keep textures when using the CAD optimizer?
Hi All,
I've got a fairly large Creo View file that has a number of textures in it to represent screens on the real product.  As it's a big file, I'd like to use the CAD optimizer to reduce down the files size for the experience, but the problem is that this removes the textures from the models.  The images are still in the High, Medium and Low Creo View files, but the OL geometry file doesn't use them.
I've been playing around with the pvaroptimizer.pvr file that stored in C:\Users\<username>\Documents\ThingWorxStudio\Projects\node_modules\cad-import-filters\import_filters\win64\recipe and have added in adapter/useTexture=1 but this doesn't work.
Does anyone know how to keep the textures when using the CAD optimizer?
Many thanks,
Allan
Sep 4, 2018 12:13 PM UTC
So I have discovered that in the current version of Studio (8.3.3) the CAD Optimizer now no longer removes textures. Smiley Happy
I'm not sure when this came in but it's great that it doing it this way now.
Feb 20, 2018 7:38 AM UTC
Editing the recipe file could help.
martin
Mar 7, 2018 10:17 AM UTC
Have you found a sollution? Would be great if you could share the method, if you have found one 🙂
Aug 1, 2018 1:01 AM UTC
Not a solution, but a workaround: https://community.ptc.com/t5/Studio/Adding-a-background-image-to-a-modelitem/m-p/563992#M3844
Cheers,
Allan
AllanThompson16-PearlAuthorAnswer
Dec 3, 2018 12:55 PM UTC
Does anyone know if there are detailed instructions of how to use the Optimizer?
I see discussion about people having problems using it but no where do I see how to use it.
Any help would be appreciated.
Brad Bigelow
