Jun 18, 2019 7:00 PM UTC
How to load a project without using a Thingmark
I'm trying to export a project and place it onto the hololens. I am wondering if it's possible to load the project without using a thingmark; is it possible to access the hololens's files and just place the contents directly into the application and have it start upon loading up Vuforia View?
jmikesellAnswer
Jun 19, 2019 3:38 PM UTC
I don't think you can load it directly as there are some build steps that happen when you publish. But if you have you experience open in Studio there is a share button at the top. This will give you a URL and a QR code that will open the experience in View. You should be able to scan this QR code in View on the hololens and ope the experience.
jmikesell1-VisitorAnswer
