Jul 18, 2024 5:58 AM UTC
How to Navigate between downloaded experiences in Vuforia Studio
How can we navigate between Vuforia Studio Experiences in Vuforia View app if the experiences we are viewing are downloaded for offline view.
Thanks in advance.
Aditya Gupta
Jul 18, 2024 7:25 AM UTC
Hi @Aditya1702 ,
when you meant navigate you means to open an expeirence from inside proejct?
Because you will be able to go to the Downloaded experience tap and could select one of the downloaded epxeriences. But obviously you does not mean that point.
Also another important question  is : if the started  Vuforia   View app could see the experience Server from where the Experience Project was downloaded. I think in the past this was relevant in the behavior.  That I need to check in the current version.
But what is your issue. Did you check some action what is not working? e.g. simple open the experience via link from server / even when the server is not visible ?
Jul 18, 2024 7:32 AM UTC
Hi @RolandRaytchev,
Thank you for your response.
Yes I mean opening the other experience from inside experience.
I tried the below solution:
https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/TutorialExperienceFromExperience.html
Its working incase I am connected to the internet but when I try from the downloaded experience tab it does not navigate to other project from inside.
Jul 18, 2024 8:02 AM UTC
thanks for the clarification.  I think there is a post what reprorted similar requirment https://community.ptc.com/t5/Vuforia-Studio/Download-the-experience-QR-code-from-Vuforia-View-application/td-p/949742
to that we have an enhancement VTS-2001 what is under consideration  by the Vuforia Product managment team.
Because your quesion possible differs from that ticket - therefore I reported that to R&D /Product managment as VTS-2077 to check if there is change or change planed. Thanks
