Oct 13, 2020 7:10 AM UTC
How to obtain all the name of pdf into upload folder
Hi everyone,
in my project I need to load a lot of file.
I'm searching for a procedure able to:
- read the name in 'app/resources/Uploaded/' + documentName + '.pdf'
- save documentName into a json file
In such way i could be able to launch the visualization of the file into 2d canvas, with a function like this one bind to a button that pass the parameter 'documentName':
$scope.showDocumentation = function(documentName){
var anchor = document.createElement('a');
anchor.href = 'app/resources/Uploaded/'+documentName+'.pdf';
window.location.href = anchor.href;
With the json file I want to load the file without typing every single name with my fingers.
Any suggestions?
Oct 13, 2020 12:01 PM UTC
Hello @leonardosella ,
just to clarify:
- read the name in 'app/resources/Uploaded/' + documentName + '.pdf'  ->
->>> in this case you want check the app/resources/Uploaded folder if an particular document is there ? Or you don’t know the name of the documents , and you want to do something like ... dir ...  or ls...  of the app/resources/Uploaded/ folder
- save document Name into a json file-   Where you want to save the json file?
If you want to change it locally back to the folder   app/resources/Uploaded/ - I do not believe that this is possible /allowed    .
Or do you have other web. server where you want to save it.
Json information could be read from the app/resources/Uploaded/  folder but it could not be modified / modification only in session possible. Also, you can send the modified json data  to a web server or TWX server(thingworx)
Oct 13, 2020 1:12 PM UTC
Hi @RolandRaytchev,
1. I want to check the /../Uploaded/ directory and access the name of the pdf files, I don't know this prefix;
2. I made a mistake, don't save into a json file, only save the name on documentName.pdf into an object.
Oct 14, 2020 7:15 AM UTC
Thanks for the clarification.
to 1.) this is directly not part of the funcitonaltiy but there was discussion in the post : "Show all Files of a Folder" - I hope this could be helpfule
2.) Ok when you find the name there will be  no problem the modify a json object and update the name or insert the new name / or object  to the json list. Afterwards  you can upload it to server or TWX
