Jul 24, 2024 3:13 PM UTC
How to set input of a ThingWorx service from Vuforia Studio
I have a service in ThingWorx with some inputs inside it.
I want to set those inputs from Vuforia Studio.
Can anyone help me out asap please?
Thanks in advance.
Aditya Gupta
18-Opal
Jul 24, 2024 8:32 PM UTC
The easiest way is probably to bind an application parameter to the service parameter. Once you have added the service to your External Data, you'll see a Parameters entry under it, open that and you can use drag and drop bindings to send data to the service.
