Jun 14, 2018 11:03 AM UTC
how to show complete model again after hiding some sub-parts
I want to make an experience where modelItems can be hidden by tapping on them, and where I have a restore-button that shows all modelItems again.
I am using a simple js for hiding the modelItems:
$scope.Hide= function(val) {
 $scope.view.wdg[val]['visible']=false;
This works fine, by using this call:
Hide('name-of-the-modelItem')
So far, so good.
However, for showing all models I made a modelItem of the complete model, and I called this function (almost identical to the Hide function):
$scope.Show= function(val) {
 $scope.view.wdg[val]['visible']=true;
But... this does not work on the modelItem that I made of the complete model, only on sub-assy-modelItems.
Is this a bug, or are the visible-properties of the sub-modelItems blocking the correct display of the 'visible'-property of the total-model-modelItem??
The point is, I could call the Show-function for all sub-modelItems one by one from a new function, but that's more work, more code... and this experience will be used on a model with quite a few subassies.
Jaap
Jun 15, 2018 10:34 AM UTC
Oops.  Sorry, I didn't scroll down far enough.
Here's all the code:
// Hide all elems containing text defined in variable genericStepText
$scope.app.hideElemsIfContains(genericStepText);
// Show specific elements containing text defined in variable specificStepText
$scope.app.showElemsIfContains(specificStepText);
$scope.app.hideElemsIfContains = function(testExpression) {
var allElems = document.getElementsByTagName('*');
for (var i = allElems.length; i--; ) {
if(allElems[i].id.indexOf(testExpression) !== -1){
$scope.setWidgetProp(allElems[i].id, "visible", "false");
$scope.app.showElemsIfContains = function(testExpression) {
$scope.setWidgetProp(allElems[i].id, "visible", "true");
The semicolon ; and close bracket ) that are coloured red above don't need to have a space in between them.  Not if it's important or not, but the message keeps converting them to a 😉 so I had to put the space in there.
Allan
Jun 14, 2018 11:38 AM UTC
I belive modelItems override the model visibiltiy. And having two model items trying to control the same parts, say at two different assembly levels like you tried, causes weird problems. I would recoment trying the code below.
$scope.showAll = function () {
 labels = document.querySelectorAll('[id^="modelItem"]'); //all items that start with modelItem
 for (i = 0; i < labels.length; i++) {
 console.log(labels[i].id); //will write ids to console for checking
 $scope.view.wdg[labels[i].id]['visible'] = true;
jkramer12-AmethystAuthor
Jun 14, 2018 6:04 PM UTC
Thnx for this one!
I tried it, but it seems that the line
doesn't work, although I made sure my modelItems have a name starting with modelItem...
Is there a way of inquire the type of the widget? That would make it independent of the name.
Any suggestions?
Thnx!
Jun 14, 2018 11:24 PM UTC
Here's some code that our Java guru wrote for me to use in an experience.  The idea was to hide/show a mix of 3D models and/or 3D images in an AR service experience. I used a naming convention for all of the items and then defined variables to say what to look for.  This bit of code was inside a loop that incremented though each step in the service procedure:
Hope this helps.
Allan
