Aug 10, 2021 7:14 AM UTC
How to show compression of spring in creo illustrate without using creo mechanism(animation) ?
I am working on one complex assembly project where in between sequence I need to show the compression of spring followed by forward movement of piston. How to achieve this in creo illustrate without using Creo parametric (Mechanism/Animation- no license).
Thanks in advance
Aug 10, 2021 8:02 AM UTC
The only method I know of to show this would be to have two models of the spring, one in the compressed state and the other in the uncompressed state. You would then swap one out for the other.
Not an animation as such but Illustrate does not have the ability to deform solid bodies.
Aug 10, 2021 11:33 AM UTC
I m already using this.apart from this is there any other method or manipulation
