Jamal Ashraf
Aug 14, 2024 8:56 AM UTC
How to show live timer in studio in Label Widget
Dear Community,
I want to show the timer in the studio in label widget but it does not get update as you can see my function also below. any idea how to achieve this functionality? when i run some other function then it gets render otherwise not.
Thank you
function startCountdown() {
 var countDownTime = 95 * 60 * 1000;
 var x = setInterval(function() {
 // Decrease the time left by 1 second (1000 milliseconds)
 countDownTime -= 1000;
 // Time calculations for minutes and seconds
 var minutes = Math.floor(countDownTime / (1000 * 60));
 var seconds = Math.floor((countDownTime % (1000 * 60)) / 1000);
 // Update the text in the widget
 $scope.view.wdg["overAllTime"].text = minutes + "m " + seconds + "s ";
 // If the countdown is over
 if (countDownTime < 0) {
 clearInterval(x);
 $scope.view.wdg["overAllTime"].text = "TIME UP";
 // Start the countdown again
 startCountdown();
 }, 1000);
// Start the countdown when the script runs
startCountdown();
Jamal Ashraf
Aug 14, 2024 12:02 PM UTC
Solution: I am giving time in seconds and bind the count param with text of label and its working perfectly fine. Its showing hh:mm:ss.
 $scope.$on("$ionicView.afterEnter", function (event) {
 $scope.startCounter();
$scope.countdownTimer = function() {
 if ($scope.app.params.timeLeft > 0) {
 $scope.app.params.timeLeft--;
 var hours = Math.floor($scope.app.params.timeLeft / 3600);
 var minutes = Math.floor(($scope.app.params.timeLeft % 3600) / 60);
 var seconds = $scope.app.params.timeLeft % 60;
// Format the time as HHh MMm SSs
var formattedTime = hours + "h " + (minutes < 10 ? "0" + minutes : minutes) + "m " + (seconds < 10 ? "0" + seconds : seconds) + "s";
 $scope.view.wdg["overAllDownTimer"].text = formattedTime;
 } else {
 $scope.stopCounter();
 $scope.view.wdg["overAllDownTimer"].text = "00h:00m:00s"
$scope.startCounter = function() {
 $scope.app.params.timeLeft = $scope.app.params.timeLimit;
 $scope.intervalPromise = $interval($scope.countdownTimer, 1000);
$scope.stopCounter = function() {
 $interval.cancel($scope.intervalPromise);
Documentation : https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/IntermediateJSInterval.html
Jamal Ashraf
Jamal Ashraf16-PearlAuthorAnswer
 } else {
