Jan 3, 2020 4:48 AM UTC
how to show the sequence on button rather than showing using squence list.
$scope.setSequenceList = function(){
$scope.app.params.sequencelist = [
"display":"FAN SERVICE",
"value":"app/resources/Uploaded/l-Creo 3D - FAN SERVICE.pvi"
"display":"FAN REPAIR",
"value":"app/resources/Uploaded/l-Creo 3D - FAN REPAIR.pvi"
"display":"HARNESS REPLACE",
"value":"app/resources/Uploaded/l-Creo 3D - HARNESS REPLACE.pvi"
$scope.setSequenceList();
$scope.selectSequence = function(){
console.log($scope.app);
if($scope.app.view.RepairSequence.wdg["sequence-select"].value){
$scope.app.view.RepairSequence.wdg["bottom-nav-grid"].visible = true;
$scope.app.view.RepairSequence.wdg["select-popup"].visible = false;
else {
$scope.app.view.RepairSequence.wdg["bottom-nav-grid"].visible = false;
$scope.app.view.RepairSequence.wdg["select-popup"].visible = true;
This is the code i am using to show the sequence through sequnce select list.
Now i need to show each step on different button individually
Jan 3, 2020 11:49 AM UTC
Hello Manoj,
Please change model ID and Step number so you can use this code.
Please find below code and read it carefully so you can get my point.
$scope.sequence1 = function () {
$scope.$applyAsync(()=>{angular.element(document.getElementById('Model-ID')).scope().reset();});
//does not work synchronously
//delay of .5 sec to be sure that all action are done
$timeout(function () {
$scope.$applyAsync(()=>{$scope.setWidgetProp('model-1', 'currentStep', your_step_number);});
//further delay for a 0.5 sec to be sure that the step is set and then play
$timeout(function () {$scope.$root.$broadcast('app.view["Home"].wdg["model-1"].svc.play'); }, 500);
}, 500);
Jan 3, 2020 5:52 AM UTC
Hello Manoj,
As per your question, you want to add each step/sequence on different button
so please find below code for same.
 Please change Model Id & Step No. for same.
$scope.$applyAsync(()=>{angular.element(document.getElementById('model-1')).scope().reset();});
$scope.$applyAsync(()=>{$scope.setWidgetProp('model-1', 'currentStep', 2);});
}, 500);
Jan 3, 2020 11:05 AM UTC
Hello Swapnil,
Thanks for replying.
there is an issue encountered ,using this code i have to place three different model and then show the three sequence.
I just want to place one model and then show the three sequence in three different buttons.
Regards
Manoj
Hello Manoj,
}, 500);
