Apr 27, 2020 10:09 AM UTC
How to upload Extra Thingmarks provided by PTC to our own premise experience server ?
Please share the document of uploading the extra Thingmarks to the experience server.
Thanks in advance.
Apr 27, 2020 11:51 AM UTC
@ranjank  Refer to an existing thread for steps and solution to your query -
https://community.ptc.com/t5/Vuforia-Studio/How-do-I-import-the-additional-thingmarks-given-to-the-customer/m-p/572403
ranjank1-VisitorAuthor
Apr 27, 2020 3:06 PM UTC
@RolandRaytchev Thanks for your input on the article shared by @dupatel  but there is one problem is that I don't want to lose my existing experiences present in my 3 default thingmarks.
What I found in JSON is that there is one option of "thingmarkDomain" which means all the extra thingmarks including the default ones are having the same value as per your screenshot.
I tried ur solution but the existing experiences got vanished which were present in 3 default thingmarks.
Could you pls let me know can we put more than one thingmarkDomain value so that we cannot lose any of our existing thingmark experiences with different thingmark domain.
Apr 28, 2020 4:56 AM UTC
@ranjank  The default Thingmarks are associated with a particular thing mark domain and are provided with your Studio Trial account. However, since you already have setup On-premise ES so should update the existing ThingMarks and also should publish your existing projects to your own On-premise ES. Then there will be no need to keep old Thingmarks.
In case you still want to keep the old ThingMarks then should not update the new ThingMarks inside Studio application. You can continue using the on-premise new Thingmarks ID directly and scan the ThingMarks using an e-copy or printed version of Thingmarks.
