Important Update: Experience Service Will Require HTTPS in Vuforia Studio 10.5
As part of our ongoing commitment to security, platform reliability, and simplified deployment, Vuforia Experience Service will no longer support HTTP connections beginning with the planned release of Vuforia Studio 10.5, currently targeted for the end of November. Experience Service deployments will be required to use HTTPS.
What Is Changing?
- Experience Service deployments configured for HTTP will no longer be supported.
- Vuforia Studio Editor and Vuforia View will only connect to Experience Services configured with HTTPS.
- Customers using HTTP-based Experience Service deployments must migrate to HTTPS.
What You Need to Do
If your Experience Service is already configured for HTTPS, no action is required.
If you are currently using HTTP:
- Reconfigure Experience Service to use HTTPS.
- Update any required TLS certificates.
- Republish your experiences and verify connectivity.
Need Help?
If you have questions about migrating from HTTP to HTTPS, please review the TLS certificate configuration documentation in the PTC Help Center.
