Oct 12, 2020 12:44 PM UTC
Impossible to configure VS Trial
Hello, I have a problem while connecting to my account to configure Vuforia Studio I have an eroor "Application not found", the description of the of the error.
PS: I tried to uninstall and install again but it doesn't work.
System.ComponentModel.Win32Exception (0x80004005): Application introuvable
à System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
à System.Diagnostics.Process.Start()
à System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
à com.ptc.ThingworxStudio.MobileBuilderForm.btnLogs_Click(Object sender, EventArgs e)
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.Label.WndProc(Message& m)
à System.Windows.Forms.LinkLabel.WndProc(Message& msg)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Oct 29, 2020 9:12 AM UTC
Hello @sdidier, I found where the problem comes from, it is because my cnnexion was bocked so i just installed VFS in another computer connected to another network and all work properly.
Thank you for your time,
Thomas
Oct 13, 2020 9:52 AM UTC
  • Does Vuforia Studio is present in Windows Explorer in this folder %USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io ?
  • What is the size of this studio-download.vuforia.io folder ?
  • What do you have in the folder %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PTC Inc ?
  • Does an antivirus is installed on this workstation ?
Best regards,
Samuel
Oct 13, 2020 10:58 AM UTC
Hello @sdidier, thank you for your answer.
  • Vuforia studio is not in the folder %USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io
  • The size of studio-download.vuforia.io is 465 Mo.
  • I have Vuforia studio .exe in the folder %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PTC Inc .
  • Yes i have an antivirus installed on this workstation.
I guess Vuforia Studio is not installed in the correct folder ?
Best regards,
Thomas
Oct 13, 2020 1:45 PM UTC
If Vuforia Studio is not in this folder %USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io  where is located in your computer ?
Best regards,
Samuel
