Oct 15, 2019 1:38 PM UTC
Integrate Vuforia Experience Service on Premise on the Windows Server 2008 R2 version
Is it possible to integrate Vuforia Experience Service on Premise on the Windows Server 2008 R2 version?
Have you already tried it? It works.
regards,
Matteo
sdidierAnswer
Oct 15, 2019 2:21 PM UTC
Hello Matteo,
I have looked the documentation Installing and Deploying an Experience Service 8.4.6.
https://www.ptc.com/support/-/media/6FCDB63E6C444D5CA0DEE998A52AC8FF.pdf?sc_lang=en
At the page 10, in the chapter Experience Service Requirements, in Operating System array ; only Windows Server 2016 64-bits has been listed as Windows OS.
So, it means Windows Server 2008 R2 has not been tested by PTC R&D and Q&A.
It means also not supported by PTC.
What do is it mean not supported ?
It means, an issue reported n a such OS and if the issue is only reproducible with this OS, a Jira ticket will not be reported to R&D and we cannot expect a fix.
If the problem is reproducible in an OS who is supported, we can have a Jira ticket and a fix from R&D/
By the way, I have install Vuforia Experience Service in Windows 10 without any problem.
I was using it to do tests without any problem.
So, not supported doesn't mean, it will not work.
Best regards,
Samuel
sdidier17-PeridotAnswer
Hello Matteo,
Best regards,
Samuel
