Is it possible to set a default value for choosing a sequence animation during runtime?
Hello everyone,
based on Can't use more than one sequence animation in a single experience in ThingWorx studio. I implemented the second solution. When I load the application, there is an empty value set (no animation sequence is selected). I have to choose an animation sequence first. Is it possible to define a default value, e.g. in this case a default sequence which is automatically chosen from the beginning?
You can try setting Model widget's "Model Loaded" event with a JS code that assign the model with the desired Sequence file.
FYI, JS code to set sequence -setWidgetProp( 'model-1', 'sequence', '3D explode.pvi');
Unfortunately this doesn't work with the second solution of Can't use more than one sequence animation in a single experience in ThingWorx studio.​ When implementing the first solution the JS code works fine, but my problem doesn't occur then since there is a sequence seleted from the beginning. I don't know why, but by implementing the second solution the code stops working.
So is there another possibility to assign a default value?
Edit: After I selected a sequence, the code seems to work again (I have two buttons which also reference each to one sequence using the code you proposed. They don't work until I selected a sequence per select bar, but after that I can use them, too).
