Is there any tutorial available on how to use time series chart or bar chart in Thingworx Studio?
I want to add a time series chart in my experience where the x axis will be time and y axis will be RPM value of the Car1 Thing. Can you provide some tutorial for that?
Thank you...
ankiguptaAnswer
Hi Dipika Sengupta​,
TimeSeries chart requires an infotable (timestamp and values) to show the Series. Try binding the output of QueryPropertyHistory service from ThingWorx to the Studio TimeSeriesChart. Then set the X-axis Field name as timestamp and Y-axis Field name as RPM.
I hope it helps.
I just checked the ThingWorx Studio Tutorial Hub but didn't find the Time Series Chart. I will check internally if it planned for future.
I can help you with any specific issue regarding the time series chart.
Hi Ankit,
Thank you for your response...
I have bind the RPM to the Data field of the time series chart. But when I am seeing it in the preview or in the view app, it is showing that data is not loaded. Can you tell me how can I do it?
Dipika
ankigupta5-Regular MemberAnswer
I hope it helps.
