Feb 1, 2022 12:54 PM UTC
Issue for starting 3D Video from JS
Hi all,
I am currently developing a step-by-step instruction for HoloLens 2 that should play a video when the next step is triggered. For this, I have written some JS code that switches the step (containing animations and switch in the step description). The issue that is comming up when I run the code below is that the status of the video is constantly switching from play to pause and backwards.
A minimal snippet of the code I use:
getCurrentTitleLookUp = function (stepNumber) {
 //initialize variables
 switch (stepNumber) {
 case 1:
 //Changing labels and instructions
 //Setting the video source
 $scope.setWidgetProp("3DVideo-1", "src", "app/resources/Uploaded/Videos/Step-1.mp4");
 //Play the video
 twx.app.fn.triggerWidgetService("3DVideo-1", "play");
 //play animations
 break;
//goes on for all steps.
//That method is called on a button-click.
$scope.app.nextStep = function () {
 stepNumber = stepNumber + 1;
 getCurrentTitleLookUp(stepNumber);
// here is some logic for assemby
The following output gives me the log constantly:
3DVideo-1 userpick play button video3D-ng.js:150
pause 3DVideo-1 video3D-ng.js:218
3DVideo-1 userpick play button video3D-ng.js:139
play 3DVideo-1 video3D-ng.js:206
3DVideo-1 userpick play buttonvideo3D-ng.js:150
I used the following snipped for replaying the video, also on a button-click. There it works perfectly.
Does anybody have an idea what I am doing wrong? I ran out of ideas, especially because it's working with the replay, but I am not sure what I am doing differently.
Thanks in advance!
Marius
Feb 1, 2022 5:20 PM UTC
Hello @mol22 ,
l
looking in  code of you post but unfortunately for me is not clear what  is the issue.   You mentioned it works perfectly but I could not see what is not working. Could you explain, please, more detailed, possibly the context where your code is called.
In generally when you set a property and then trigger a service which used this property – then this is possibly it is not working - you can try the subsequent call it after async or with some delay
// async call
$scope.$applyAsync();
//Play the video with delay
 $timeout(() =>{ twx.app.fn.triggerWidgetService("3DVideo-1", "play");},1000);
//e.g. 1 second delay
you mentioned also "instruction for HoloLens 2 that should play a video when the next step is triggered" :
so how did you triggered the next step - do you use some listener e.g. new Step, step completed or step finished (as described in the post about Vuforia Studio Events)
So far, I see you used the simples scenario via click on a  button to call the next step - which means here it should perform first a  setting of src property  then will play( widget play service)  the video file for the next step. I think this should so far work in the normal case
Another code version trying to play the code could be :
$scope.testPlay2= () =>{
var element = angular.element(document.querySelector('twx-widget[widget-id=\"3DVideo-1\"]'));
element.scope().play();
… Here is also a list of different attempt  which will have more or less success to call the 3DVideo widget play service – I found them in  some old projects but did not test if they all will work
 try{app.view["Home"].wdg["3DVideo-1"].svc.play;} catch(ex){console.warn("ex="+ex);}
try{twx.app.fn.triggerStudioEvent('3DVideo-1', 'play');} catch(ex){console.warn("ex="+ex);}
try{$scope.$root.$broadcast('app.view["Home"].wdg["3DVideo-1"] .svc.play');} catch(ex){console.warn("ex="+ex);}
 // this below is working when button 3DButton-2 has binding to the play event
try{twx.app.fn.triggerStudioEvent(document.querySelector('[widget-id="3DButton-2"]'), 'click');} catch(ex){console.warn("ex="+ex);}
try{twx.app.fn.triggerStudioEvent(document.querySelector('[widget-id="3DVideo-1-play"]'), 'click');} catch(ex){console.warn("ex="+ex);}
try{twx.app.fn.triggerStudioEvent(document.querySelector('[widget-id="3DVideo-1"]'), 'click');} catch(ex){console.warn("ex="+ex);}
try{twx.app.fn.triggerStudioEvent('3DVideo-1-play', 'click');} catch(ex){console.warn("ex="+ex);}
 try{
 $scope.app.fn.triggerWidgetService("3DVideo-1","play");
Hello @mol22 ,
l
// async call
 try{
mol221-VisitorAuthor
Feb 3, 2022 8:34 AM UTC
Hi @RolandRaytchev,
thanks for your response! Your first suggestion did the trick. It appears that I had to wait till the Video is loaded. I even need to wait more than one second till I am able to play it. Otherwise it's not starting.
Thanks again!
Marius
Feb 3, 2022 3:41 PM UTC
Hi @mol22 ,
thanks for the feedback and  I am hapy to hear that it was working in your case. But when we use a  solution like this:
$scope.testJsPlay= function() {
 $scope.setWidgetProp("3DVideo-1", "src", "app/resources/Uploaded/sonne1.mp4")
 $timeout(() =>{
 try{
 ,6000); //e.g. 6 second delay !!! possibly to long
we need to ensure that we will delay enough long time  (here in the example 6 seconds - which is very long) so that the play service  call will work. If we use a video with large size and call it from some  location where the connection is slow ... possibly it will not work. So here is an attempt to have a workarounbd for this issue with fetch request (the url should be http or https which CORS conform)
//in one button this function on click -local large file
app.testPlay('app/resources/Uploaded/20201103_173339_HoloLens.mp4','3DVideo-1');
//this def for second button to play test video form http url
 app.testPlay('http://commondatastorage.googleapis.com/gtv-videos-bucket/sample/ForBiggerJoyrides.mp4','3DVideo-1');
Here I have the function defintion what I used. In my test it was working fine on HL2. It will not play in preview mode - work only on device (according to the Studio Help.- this widget does not work in Preview- error some message like "no shader defined") Therefore to  test also in preview mode if the data is received I have here some test printings which should be removed on the HL2 - because it is then to slow
$scope.app.testPlay= function(url,widgetName) {
 $scope.wdgName=widgetName
 console.log("---->widgetName="+widgetName)
 $scope.setWidgetProp($scope.wdgName, "src", url)
 // here I will load the file to estimate the time
 console.log("before fetch("+url+") time ::" +$scope.getTime());
 fetch(url)
 .then(response => response.blob())
 .then(blob => {
 var reader = new FileReader()
 reader.onload = function(){ console.log("onload time ::" +$scope.getTime());
 	var dataURL = reader.result;
 	 $scope.app.view["Home"].wdg[ $scope.wdgName].src='data:video/mp4;base64,'+ dataURL;
 // this print below will print the data -but is not efficient on device !
 console.warn( $scope.app.view["Home"].wdg[ $scope.wdgName].src)
 };//end of onload funciton def
 //load end
 reader.onloadend = () => {
 console.log("onloadend time ::" +$scope.getTime());
 $timeout(() =>{
 $scope.app.fn.triggerWidgetService( $scope.wdgName,"play");
 },1500) //1,5 sec delay to sync
 } //onload end
 reader.readAsDataURL(blob)
//================ print time for check
$scope.getTime = function() {
var date = new Date();
var h = date.getHours(); // 0 - 23
var m = date.getMinutes(); // 0 - 59
var s = date.getSeconds(); // 0 - 59
var session = "AM";
if(h == 0){h = 12;}
if(h > 12){h = h - 12;session = "PM";}
h = (h < 10) ? "0" + h : h;
m = (m < 10) ? "0" + m : m;
s = (s < 10) ? "0" + s : s;
var time = h + ":" + m + ":" + s + " " + session;
return time;
