Apr 8, 2019 12:44 PM UTC
Issue with Sequence Launch
I have 2 issues.
1. The model has two sequences ( Figure 1 & Figure 2 ). I leave the sequence options under model props empty so that I can set the sequence later through JS. I am using the following JS to set the sequence :
$scope.view.wdg['model-1']['sequence'] = 'l-Creo 3D - Figure 1.pvi'; ,
Now, While it works for only one sequence, the same does not work when I call Figure 2.
2. Second issue is that, Figure 2 is a Dis-Assembly snapshot, for some reason, the minute the experience is launched, the model locks into the Figure2 View and hence starting in the Dis-Assembly view which is not intended.
Somebody pl help!!!!
Avinash
Apr 8, 2019 1:16 PM UTC
I have some questions :
  • In which version of Creo Illustrate the Sequences have been made ?
  • Is it possible to share the project ?
Without it, it will be difficult to debug that.
Best regards,
Samuel
agangaiah5-Regular MemberAuthor
Apr 8, 2019 3:43 PM UTC
Hello Samuel, I use Illustrate 5.1 and Yes, I can share the project file. Avinash
May 9, 2019 1:33 PM UTC
Hello Avinash,
  • Can you upload the Project in this thread?
Best regards,
Samuel
