Feb 22, 2021 7:24 AM UTC
Issues with Hololens 2 - Model Target
I've created project with model target detection using 3D eyewear. Now, I would like to view the sequence in Vuforia View using Hololens 2. But, sadly I'm not able to reach the Vuforia View library even using voice commands stated in http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FEyewearViewAndHololens.html.
Vuforia View not even detect commands that I gave. It always and only display scan outline even though I've successfully configured ES URL.
Hope somebody can advice on this issue. Really need an urgent response.
Many thanks.
Feb 22, 2021 8:15 AM UTC
did you try to scan the QR code for your experience?  Use the share tab in studio to see the QR code.
Anyway you should be able to to access the library with voice commands. Can you confirm that voice commands outside of the view app are working?
AS161-VisitorAuthor
Feb 22, 2021 8:22 AM UTC
i. did you try to scan the QR code for your experience? - Yes
ii. Can you confirm that voice commands outside of the view app are working? - Yes. Its working fine.
Feb 22, 2021 8:30 AM UTC
Okay, you tried but it could not recognize the QR code? Sometimes you need to download it and make it larger.
Do you get any audio feedback after you say "Hey view"?
