Jan 7, 2022 11:59 AM UTC
Issues with RealWear HMT-1 Help Bubbles
In RealWear HMT-1 Experiences there seems to be a problem with the $interval function.
When this function is used all the bubbles in the experience are blinking. Even tho some of them should be invisible (in a popup). While this occurs the RealWear doesnt recognise the right bubbles so the user cant interact with the bubbles.
setInterval should solve this problem according to PTCs R&D.
Hope this helps.
VladimirNAnswer
Jan 7, 2022 12:08 PM UTC
VladimirN24-Ruby IVAnswer
Please send your issue here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
