.js Function Exection on Service Completion
  • August 20, 2021
  • 5 replies
  • 2770 views
How would I code a function to execute every time a service is completed? I would like to use js instead of bindings.
Best answer by ailko
To execute javascript code in studio home.js when a TWX service added in the External Data would trigger a "ServiceInvokedComplete" event you can add the following in the home.js to intercept that event and run code that doesn't require leveraging the bindings in studio:
$scope.$on('myTWXService.serviceInvokeComplete', function(evt, arg)
// do code after myTWXService executes
ailko5-Regular MemberAnswer
Ike@ACE15-MoonstoneAuthor
What are the two parameters that are passed into the function (i.e. evt and arg)?
This is just the OOTB function definition for the serviceInvokedComplete trigger in Studio, as far as the values I've never needed to leverage them for my usecases or know what their values are but you can use console.log() in the home.js and the values will show up in the Console tab of dev tools. ie console.log(evt)
