Apr 17, 2018 7:23 AM UTC
Label bindings
I cannot bind a click event of a label to the visibility of another label (eyewear project).
Same with 3d images - why?
Is there a way to do this with json? If yes, can someone help me with the syntax? I'm not very familiar with coding.
Version: 8.2.2.3099
DF
Apr 17, 2018 3:06 PM UTC
Here is my suggestion:
  • Edit the <<viewname>>.js file and paste the following code to create a function named OnLabelClick that will make the second label visible:
$scope.OnLabelClick = function() {
	$scope.view.wdg['3DLabel-2']['visible'] = true;
  • Replace '3DLabel-2' above with the Studio ID of you second label (the one you want to make visible) and press Save.
  • Select the First Label where you will fire the "Click" event
  • Under Events, press the JS button close the the "Click" event
  • Paste the following code that will execute the Function we've created:
OnLabelClick();
  • If the above works for you, you can change the function name (case sensitive) and change more than one label at a time by adding more changes to the function.
Good luck,
Ricardo
DFFHTW1-VisitorAuthor
Apr 18, 2018 10:10 AM UTC
thank you very much! This helped a lot.
Is there a list anywhere with all available commands for the home.js like the $scope.view.wdg?
In specific, whats the command for starting the sequence of a model?
DF
