Mar 9, 2021 7:36 PM UTC
Label doesn't update on Select widget item change.
Hello.
I have a Select widget that is populated locally, through an array declared in Home.js. An oversimplification of my problem: Whenever a new item is selected from the Select widget, I want a label to be updated with another value, being passed through an Application Parameter. I sort of managed this behaviour, but there's something wrong. When I select another item from the list, the label stays the same. When I select another item from the list, the label changes to the value that should've appeared in the previous case. Every time I select something from the Select widget, the label updates with the value that should've appeared the step before.
Can anyone tell me what am I missing? For reference, this is the array that populates the dropdown:
$scope.view.wdg["select-1"]["list"] = [
 display: "UC2",
 value: "1"
 display: "UC3",
 value: "2"
 display: "UC4",
 value: "3"
My Application Parameter is called maxSteps, and I populate it through
$scope.app.params["maxSteps"] = 10; //or any other value
I have a function that I set on the Select widget, on the Value Changed attribute, called onSelectChanged(), that tries to change the Application Parameter maxSteps. After the change is made, a label widget is changed with the value taken by the maxSteps property (where I think I'm mistaken).
This label change is done through a scope watch on the maxSteps variable, but it doesn't seem to work.
Does anyone have any suggestions how should I proceed? Thank you very much!
sebbenAnswer
Mar 11, 2021 5:29 AM UTC
I think I understand what you want to do but I am not sure why you get the last value of the select widget...
So like this it is working for me:
angular.element(document).ready(function() {
 $scope.view.wdg["select-1"].list = [
 display: "UC2",
 value: "1"
 display: "UC3",
 value: "2"
 display: "UC4",
 value: "3"
$scope.onSelectChanged= function(){
 if($scope.view.wdg["select-1"].value == "1")
 $scope.app.params["maxSteps"] = 11;
 else if($scope.view.wdg["select-1"].value == "2")
 $scope.app.params["maxSteps"] = 12;
 else if($scope.view.wdg["select-1"].value == "3")
 $scope.app.params["maxSteps"] = 13;
So when I select UC2 the label shows directly 11, for UC3 12 and for UC4 13.
Mar 10, 2021 12:47 PM UTC
you can just connect the maxSteps parameter with the label text property.
Or you can assign the value property of the select widget directly to the text property of the label:
 $scope.view.wdg["label-1"].text = $scope.view.wdg["select-1"].value;
Radu15-MoonstoneAuthor
Mar 10, 2021 1:02 PM UTC
Thank you for your response! Unfortunately, the second option is not feasible, as there's no relationship between the value of the select drop down and the text that I want displayed on the label (which is the maxSteps value)
And the first option still strikes me with the issue: whenever I select another option in the drop down, the label updates with the value that was connected with the previous selection.
Is there any change method that has both the old value of the property, and the new value as arguments, or something?
Mar 10, 2021 1:30 PM UTC
How do you change the maxSteps parameter then?
For me, it changes to the value I select in the select widget.
