list widget js api
Hello, I want to dynamically fill a list widget with some results from js code elaborations but I can't find how to properly set up the list (JSON?) and bind the app params to the list attributes. Is there some useful documentation on this widget? Thank you!
OK, but so far I know the working way should be similar or the same. So found in some old source something like this:
$scope.populateModelList = function() {
 $scope.my_json = [
 display: "Suspension Assembly",
 value: "app/resources/Uploaded/Suspension_Low.pvz"
 display: "Arm Assembly",
 value: "app/resources/Uploaded/Arm_Assembly_Low.pvz"
 display: "Front Hub Assembly",
 value: "app/resources/Uploaded/Front_Hub_Low.pvz"
 display: "Shocker Assembly",
 value: "app/resources/Uploaded/Shock_Absorber_Low.pvz"
console.warn( $scope.my_json );
$scope.view.wdg['list-1']['list'] = $scope.my_json ;
 $scope.view.wdg['list-1']['label'] = 'display' ;
twx.app.fn.addSnackbarMessage("assemblyList was populated","twLogo");
$scope.$on('$ionicView.afterEnter', function() {$scope.populateModelList();})
where the widget was a list
Hi @GianVal ,
could you clarify what means dynamically this case- is the list of widget should be selected dynamically or the data. so reading a json file and setting using a file e.g. json data  is no problem . so far I know there is no general document how to do this but we can find any small example in the different help sources. I did in the past some similar issues in the past. E.g. setting from json file the value of repeater (mobile project test_repeater_dynamic-Elements.zip ) Here the list should be a dynamic value -received from json file. Ok here in this example the json file is fix but it could be also received form any where as json file form upload folder or form TWX repository.
In the second example  here is shown how to read  a json file and setting of values of components widget values (without explicit widget definitions)   (HL attached project propSetComponetsHoloLensExamleCommunty.zip)
of course similar to this  - it will work when we have already widgets e.g. the following code:
//Global Variables
var pjson ="properties.json"; //JSON File Name without extension
$scope.jsonData={}; //global $scope variable
gotJSON=function(data){
 try{
$scope.jsonData=JSON.parse(data);
 console.warn( JSON.stringify($scope.jsonData))
 $scope.setMutipleProps($scope.jsonData)
catch(wrong){ console.warn(wrong);}
doRead=function (jsonFile){
fetch(jsonFile)
 .then(response=>response.text())
 .then(data=>gotJSON(data))
$scope.Init=function() {
doRead('app/resources/Uploaded/'+pjson);
$scope.$on('$ionicView.afterEnter',function(){
 console.log("$ionicView.afterEnter was called");
$scope.Init();}) //event: when 2d View loaded
//the code will read the complette JSON File and
//assignee it to a jsonData global variable
//func will set mutliple widget properties according JSON
$scope.setMutipleProps = function(obj){
 Object.keys(obj).forEach(function (item) {
 for(var prop in obj[item]) {
 $scope.view.wdg[item][prop]=obj[item][prop];
 //print the setting for debugging
							console.log("==>$scope.view.wdg["+item+"]["+prop+"]="+obj[item][prop] )
This sample code will read a json file with widgets (explicit defined widgets) definition form json file (here example properties.json -attached /zip) and will try to set the properties of widget there
{"button-1":{"class":"button1"},"button-2":{"class":"button1"},"button-3":{"class":"button1"},"3DLabel-1":{"visible":false,"text":"This is PTC Remote Control Model"}}
GianVal15-MoonstoneAuthor
sorry, let me clarify. I meant the LIST widget, the widget named LIST. In general, in my js code, I want to assign values to the list items of this widget deriving from some other data. I hope the question is clearer.
ok, please check $scope.populateModelList  in the demo project (DynModelChangeUIcommunity.zip)
So it set on start the list property and do some other this but not relevant to the question
