Jan 11, 2019 8:35 AM UTC
Live IoT data shows as NaN only on IPad Pro
Hi all,
I've made a AR project in Vuforia Studio for a customer. The goal was to show live IoT data in an AR experience. This worked, but on the Ipad pro the values did not appear in the widgets, only the value NaN showed. We did test the same project in preview and on several other devices, none of them had this issue, so we think this is an issue only on the IPad, maybe on every IPad, we've only tested it in IPad pro.
Model: Ipad Pro model 2017 ios 12.1.1
Jan 11, 2019 1:17 PM UTC
@jasperlg Could you please share the Studio version and widget been used. Also, the data property on which you are observing is coming from ThingWorx entity and is it a number or string type ? Is this issue appearing on only single project or you see or can reproduce issue in new project?
-Durgesh
jasperlg1-VisitorAuthor
Jan 31, 2019 9:59 AM UTC
I'm on version 8.3.7.4156. The property type is number and I haven't tested the issue in another project.
Jasper
