Jun 21, 2017 12:12 PM UTC
low / middle quality PVZ
I've uploaded a scale 1:1 STEP-file into ThingWorx Studio and ticked the "Run CAD Optimizer". All did go well, BUT ... because it's a big model and the quality is the highest it doesn't run well on the hololens. So is there a way to control the quality of the imported model?
In Creo for example, I can choose between, low / medium / high quality before publishing the model.
Jun 22, 2017 1:59 PM UTC
E. Boer​ In most cases, even the low-size (optimized) model should work well in HoloLens, unless it is too big. For the better performance, we recommend to have a 3d model with 200k polygons, something more than that might cause some issues.
eboer1-VisitorAuthor
Jun 22, 2017 2:18 PM UTC
@giri When I view an 3D-model exported from Creo Parametric as STEP and imported into ThingWorx and publilshed it, it is at the highest resolution / quality, because when I view it with the hololens, the model is perfect, shafts are really shafts.
When I publish the model directly from Creo parametric and I select the lowest resolution / quality the shafts becomes a multi surface cylinder. Even holes becomes square holes.
So it would be nice to be able to select the quality of the model when importing it into ThingWorx Studio. Are there already some options to tweak this? How or where can I check how many polygons I have?
