Sep 23, 2019 4:00 PM UTC
Making single word bold
Is it possible to make one word bold in a paragraph when using the Text Area or Text Input in Vuforia Studio
Sep 24, 2019 7:47 AM UTC
I have tried with HTML tag <b> and </b> but without success.
After some search over the web, standard text area doesn't accept HTML styling.
https://stackoverflow.com/questions/50286692/changing-a-small-amount-of-text-in-a-textarea-to-bold
In HTML, the best way to use styling in a text widget, is to use an external third party WYSIWYG text widget.
For example, this widget in Javascript &colon;
https://codemirror.net/
  1. It is needed to add this third party library in Vuforia Studio, in the Project.
  2. In custom Javascript source code, load it. More detail here  : https://community.ptc.com/t5/Vuforia-Studio/Including-js-file-from-resources/td-p/556781
  3. In Canvas, in 3D, drag and drop a TML Text Widget
  4. In TML Text Widget, in TML Text - DETAILS panel, in Properties, in Text field, click the pencil button
  5. In Edit Text dialog bow, use the coding example provided to display it
I didn't check this approach for the moment.
Best regards,
Samuel
aoleary1-VisitorAuthor
Sep 26, 2019 1:47 AM UTC
Hi Samuel,
Thank you very much for the information and for your help.  I haven't had a chance to try your recommendation but will try and see if it works.  Thank you again.
-Ada
