Mar 13, 2018 11:58 AM UTC
Multiple .pvz Files
I want to load multiple  .pvz files using multiple buttons.
How do I do it?
PatrickOllerton
Mar 13, 2018 12:21 PM UTC
Could you use multiple 3D models (one for each .pvz) and write a function to make them visible/not visible based on the button clicks?
This should work for a basic use case.
regards,
Patrick
PatrickOllerton
Mar 13, 2018 12:04 PM UTC
Depending on what you want to do exactly, there are several ways.
There is a good example in the Help  that uses a Select widget to choose from different models. You should be able to adapt this to your specific needs.
regards,
Patrick
akanoo1-VisitorAuthor
Mar 13, 2018 12:08 PM UTC
Hello Patrick,
That was very helpful. But I want to load .pvz upon clicking a button.
PatrickOllerton
regards,
Patrick
