May 2, 2022 8:21 AM UTC
multiple thingmark/qr codes same experience
Hello, I would like to create an experience able to contain multiple thingmarks at the same time (or to make a succession of different experiences as seamlessly as possible). Let me explain: during the navigation, I would like that, by pointing to a thingmark, some information would come out; if I point to another thingmark, different information and so on.
it's possible?
sebbenAnswer
May 3, 2022 6:45 AM UTC
You just write something like this:
$scope.$on("trackingacquired",function (evt, data){
 if(data =="38861:1"){
 $scope.view.wdg["label-1"].text= "Information A"
 else if(data =="38861:2"){
 $scope.view.wdg["label-1"].text= "Information B"
Change the ID  to your thingmark IDs and you should see "Information A or B " in the label von you point  to different thingmarks. Note that you need a thingmark target in your experience.
May 2, 2022 6:00 PM UTC
yes you can use this:
$scope.$on("trackingacquired",function (evt, data){});
The 'data' will contain the thingmark ID which when you point to different thingmarks. You can use it to show different information.
GianVal15-MoonstoneAuthor
May 3, 2022 6:30 AM UTC
Sorry, can you better explain the method?
sebben14-AlexandriteAnswer
