Jan 19, 2021 3:14 PM UTC
My Vuforia Studio doesn't work
I'm not sure what happened, but Vuforia Studio doesn't work anymore. I get an error window that I've never seen for anything before no matter what I try to do in regards to Vuforia Studio. Whether I'm trying to uninstall, reinstall, or just try and start the application I end up with the same window. I've attached a screenshot of the window. Thanks in advance for any help.
Ike@ACEAnswer
Feb 4, 2021 2:35 PM UTC
I submitted a ticket with PTC Support and was able to get it fixed. It turned out that the problem was a need to delete a series of files that was within the AppData/Local/Apps/2.0 folder. Deleting everything solved the issue. No idea why, but it did. Thanks for this solution goes to Ms. Yamini Tella.
Jan 20, 2021 8:34 AM UTC
The best is to look in Vuforia Studio log file.
Is it possible to share it in this thread, please ?
More details here about to collect it:
https://www.ptc.com/en/support/article/CS292349
Best regards,
Samuel
Ike@ACE15-MoonstoneAuthor
Jan 20, 2021 2:12 PM UTC
I have two of them, so I'm going to attach them both.
Jan 26, 2021 3:11 PM UTC
Is someone going to help me with this?
Jan 29, 2021 5:18 AM UTC
I have also faced the same problem previously. It may cause because of window defender, which is probably ON. Another possibility is that If you have installed antivirus or any firewall. In this Case you need to OFF the the antivirus or Firewall, Because if you see properly vuforia studio installation file is .exe which is considered as either malware or virus. I think this description will resolve the problem
Ike@ACE15-MoonstoneAuthorAnswer
