Dec 14, 2020 7:01 AM UTC
Navigating views and showing a few different popups
Hi, I'm wondering if it is possible to change/navigate to a different view within the same project where after navigating to a different view, a few popups will be shown. I saw that there is already some post related to the issue I am having, however after viewing the older posts I am still unable to get the solution. Any help would be much appreciated!
Dec 14, 2020 7:24 AM UTC
Try the below, it will launch/switch to the view "demo_view1". You can define your popup in the new view:
$scope.$emit('app-fn-navigate', {'viewname': 'demo_view1'});
Dec 15, 2020 11:50 AM UTC
Hi, my apologies but what I'm trying to do is to change view and show the popup both at the same time by a same button. Just double checking will that code work? As I noticed that it doesn't ask require a popup number.
Dec 16, 2020 9:38 AM UTC
@CZ_9729748
If you want to change the view from view1 to view 2 and invoke the popup when switch to view2, you can:
1> Navigate to view 2 in the view 1's JS:
      $scope.$emit('app-fn-navigate', {'viewname': 'view2'});
2> In the view 2's JS, you can use the below code to invoke the popup-1 automatically after model is loaded:
     $rootScope.$on('modelLoaded', function() {
         // invoke popup-1
       $scope.app.fn.triggerWidgetService('popup-1','showpopup');
Jan 5, 2021 2:31 AM UTC
Hi, @CZ_9729748
You can do it with or without any code.
Without:
In FROM view, create a Button which Click Event Binds to TO view (navigate).
In TO view, create a empty 3D Model and a Popup.
Binds 3D Model Model Loaded Event to Popup Show Popup.
With code, please check the attachment for details.
In fact, not to much different. Same Events are used to trigger corresponding JS.
