Nov 16, 2017 7:12 AM UTC
Not able to access Composer through Studio
I am trying to access the TWX composer environment from Studio, however the composer is not firing up after keying in my login credentials, it shows the loaidng screen and nothing comes up even after waiting for 40 minutes or more. Anyone here facing the same problem.
Avinash
    Nov 16, 2017 7:38 AM UTC
    Avinash Gangaiah​: Are you facing this issue on Studio Trial instance or local setup ? Are you able to access Composer directly without access Studio?
    -Durgesh
    agangaiah5-Regular MemberAuthor
    Nov 16, 2017 8:11 AM UTC
    Hi Durgesh,
    Its a Studio local setup. Trying to access TWX composer through the local setup of Studio.
    Avinash
