Jan 5, 2020 12:41 PM UTC
Pdf within a popup
I am looking at the possibility of opening a pdf ( maybe within a Popup Widget ) within the experience.
The current option I have is to launch a pdf by clicking on a file Widget but the problem is that this will end up the opening the file in a separate window which is not desirable.
Look forward to your kind responses.
Avinash
Jan 6, 2020 4:35 PM UTC
Good afternoon agangaiah,
Try using a function:
$scope.open_PDF = function(){
window.open(<path to PDF file>); }
With this you can create the button with the icon you want and insert the function call in the action click this button
agangaiah5-Regular MemberAuthor
Jan 7, 2020 7:11 AM UTC
Thanks for the kind revert. But this will open up the pdf in a new window, right?
My requirement is to open the pdf within the view experience.
Avinash
Jan 7, 2020 5:07 PM UTC
hi agangaiah,
Exact!
With this function it opens another window as it uses some existing PDF reader on your device.
In case of opening for example a popup with PDF I do not know.
