Aug 18, 2020 12:43 PM UTC
play sequence from button
two buttons placed in 2D and a model with 7 sequences loaded into resources
1.next
2.play
button 1 to load the sequence and button 2 to play the sequence. it works but I have to click them multiple times.
$scope.next = function(){
$scope.view.wdg['model-1'].sequence = "app/resources/Uploaded/l-Creo 3D - 2.pvi";
$scope.play = function() {
angular.element(document.getElementById('model-1')).scope().play();
Aug 19, 2020 12:00 PM UTC
Use the method playAll() to play all the step of sequence.
angular.element(document.getElementById('model-1')).scope().playAll();
I Hope to help you
Giuseppe
krthk86g1-VisitorAuthor
Aug 19, 2020 12:12 PM UTC
I have used the same code but still, the error persists, I guess the loading of the sequence and apply and sync is the issue here.
