May 15, 2019 8:00 AM UTC
Play sequence while value is zero
is it possible to write a JS code to play a sequence while one of the value from thingworx is 0, and stop it if value is changed to 1. Imagine a propeller which should rotate while value is not changed.
Many Thanks
Janos
tmccombieAnswer
Jun 4, 2019 8:17 PM UTC
How do you plan to initiate the sequence? From a button, or on model load?
I set my experience up to have a button click event start the sequence. Then I call repeatSequence(); on the model PlayStopped event. This will run the sequence until the value you are watching changes.
$scope.stopSequence = function() {
 $scope.app.fn.triggerWidgetService('model-1', 'stop');
$scope.repeatSequence = function(){
 var twxvalue = $scope.app.params.TWXvalue;
 if (twxvalue == 0)
 $scope.app.fn.triggerWidgetService('model-1', 'play');
 $scope.$watch("app.params.TWXvalue", function sequenceUpdate() {
 console.log('in sequenceUpdate');
 $scope.stopSequence();
Janos19871-VisitorAuthor
May 15, 2019 8:43 AM UTC
Let me add one extension to avoid misunderstanding. I would like to repeat a sequence still a value is 0. if value changed sequence should be stop or play other sequence (stopped stage).
May 16, 2019 4:52 PM UTC
Yes, you can do that.
Create an application parameter and tie it to the TWX value you want to watch. I named mine 'TWXvalue'.  Then add the below code to your Home.JS file ensuring that you are using your widget IDs and app parameters.
 // can add value checks if needed
This will stop the current sequence playing on model-1 as soon as the value of 'TWXvalue' changes.
May 21, 2019 6:35 AM UTC
thanks for your update, but it is not exactly what I would like to get. I would like to repeat a sequence still one of the value is 0. Maybe with $timeout function it is possible. Could you write an example where a sequence is played in all minutes?
Janos
