Jun 3, 2020 1:48 AM UTC
Playing Specific step with same button
How do you play certain steps in .pvz file with only 1 button?
Example, when button is press, step 1 will animate. When the button is pressed the second time, instead of going to step 2, step 3 will animate.
sdidierAnswer
Jun 3, 2020 6:44 AM UTC
Hello Jeremy,
The solution is to create a Javascript function to play the next step wanted.
For example, please see these threads :
https://community.ptc.com/t5/Vuforia-Studio/How-to-play-all-the-Sequences-pvi-one-by-one-on-a-single-click/m-p/525858#M2615
https://community.ptc.com/t5/Vuforia-Studio/Play-specific-step-of-PVI-sequence-at-studio/m-p/552906#M3362
Of course, the source codes provided don't match your needs exactely.
It is needed to be modified.
Best regards,
Samuel
sdidier17-PeridotAnswer
Hello Jeremy,
Best regards,
Samuel
