Mar 13, 2019 2:34 PM UTC
Problem show canvas/hide canvas with Popup Widget
I do not have access to the Popup Actions menu so i can use: "Hide from canvas" and "Show on canvas".
I found a topic about that problem back to 2017 and the workaround was to resize the width and height to 1px while working and before publishing resizing everything back. Is this my only solution ?
Thanks a lot !
tmccombieAnswer
Mar 13, 2019 2:47 PM UTC
The 'hide' and 'show' actions are now located at the top of the properties panel for the widget. Once you select 'hide' the option will change to 'show'.
Please share a screenshot if you are not able to see/access this property panel.
tmccombie21-Topaz IAnswer
Mar 13, 2019 2:51 PM UTC
Thank you very much !
