Feb 27, 2019 12:50 PM UTC
Problem with locating my test material, using a device
Hi
I have no idea if this is the right location for this message - as I find the site/experience very frustrating.
I downloaded and installed the Vuforia studio trial yesterday after playing around for a while published my first experience and I'm now trying to test it out on a tablet - all it says it that there are no library experiences for https:// .......studio-trial.vuforia.io
there is a number instead of the dots above
Please advise
Feb 27, 2019 1:20 PM UTC
I see 2 reasons about that :
  1. Experience is not uploaded in the Experience Service.
  2. In Vuforia View, another Experience Service is used
To investigate more deeply :
  1. What is the Experience Service URL ?
  2. in Vuforia Studio, in the Project, in PROJECT panel,  in CONFIGURATION > Info, what is the value used in the Experience Service drop down list ?
  3. Do you have any error reported in the Vuforia Studio log file when publishing this project ?
  4. In Vuforia View, does an Experience Service URL is setup ?
Thanks in advance for your feedback.
Best regards,
Samuel
ph1lj1-VisitorAuthor
Feb 27, 2019 5:09 PM UTC
Hi
This is what I see
[2019-02-26T18:02:17.589Z] info: [twx-studio:auth:oauthHandler] Server is not OAuth https://56bd2e111bd407c7.studio-trial.vuforia.io
Feb 28, 2019 8:55 AM UTC
Edit: I have done some more check, my previous tests were not relevant
I am able to connect to the instance and to ping it correctly in Chrome, by using this URL :
https://56bd2e111bd407c7.studio-trial.vuforia.io/ExperienceService/ui
https://56bd2e111bd407c7.studio-trial.vuforia.io/ExperienceService/ping
I have found this article about the error message reported :
https://www.ptc.com/en/support/article?n=CS301318
  • in Vuforia Studio, in Portal Login, what is the Experience Service URL configured ?
Best regards,
Samuel
