Apr 28, 2023 4:04 PM UTC
Problem with View Not Displaying Creo Step Properly
In the latest experience we're working on, there is one step in the Creo file that does not View properly. The problem comes in that it does not show this problem in Creo Illustrate or in Preview, only when you use a device. I'm beginning to think that this is a Vuforia View bug, which I'm not sure I can do anything about
Ike@ACEAnswer
May 1, 2023 7:01 PM UTC
I ended up redoing the step in Creo Illustrate, and now it works the way I want it to.
Apr 28, 2023 5:10 PM UTC
Hi @Ike@ACE ,
- first , please, check if you published the pvz file with the sequence /figure in the latest Creo Illustrate version which is available to download
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=LST    Datecode: 9-1-0-0
- also just to mention, please, check if you have the latest Vuforia View version on the specific mobile platform
- What is the mobile platform what you do use currently where the issue occurred? - Is this holoLens 2 device or android or IOS. Is issue on all of them or only on specific mobile platform /if mobile project or Eyewear device if it is a Eyewear project
- sometime some effects are not working (so far I remember in older -Studio/ View releases) . So if you have some flash , or pulse and shake effect in use - so remember in oder release this lead that step was not displayed in the View app. I hope that this is currently fixed.
So possibly remove such effect and test if then it works on the mobile device.- so you could identify e.g. which part of your step , which effect cause the issue. In this case, please, let us know what are your observation , e.g. which effect is causing a problem, so that we can report this to PTC development team to be fixed in future release. Thanks.
Ike@ACE15-MoonstoneAuthor
Apr 29, 2023 4:29 PM UTC
1) I use Creo Illustrate 9.1 Professional
2) Latest version of View is installed on device
3) Device is a HoloLens 2
4) The effect in question is Transform. I just need the model to move.
Ike@ACE15-MoonstoneAuthorAnswer
