Publish failed. We couldn’t contact the Experience Service
Trying to publish the sample application, but there seems to be some problem the experience service
  1. Getting the error "Uh-oh! Publish failed. We couldn’t contact the Experience Service. Verify that the Experience Service URL is correct, and check the log for errors." when i try to publish the sample app
  2. Getting the error "Could not contact the Experience Service, verify the server is running. Error: unable to get local issuer certificate" when i try validate the experience server url in the settings
  3. In the log i see "Error: unable to get local issuer certificate"
My setup
  • Using the sample app without any modification
  • Using the default experience service URL
  • Using from public network.
No ideas how to get rid of this error. Please help
rjayaraj1-VisitorAuthor
Can someone help? We are completely struck because of this issue and unable to check any features of the thingworx studio.
Will appreciate any pointers here.
Can you let me know the email address you used to register for the ThingWorx Studio?
Thanks.
Yuxiu
I have sent a personal message to you with the email ids.
Your experience service is up as when I tried to access it, it prompted me for login credential. Have you tried again after the initial error?
Thanks.
Yuxiu
It is still not working. Even before this it used to ask us login and after login it will be unable to publish.
Hi good night everybody,
I have the same issue , I don know what is wrong , should I update the URL server ? any idea regarding this issue ? excuse me Yuxiu Weng how do you solved this issue?
Best Regards
Elias, Are you able to access your Experience Service directly?
Hi Tara ,
Sorry for the delay to answere you , I can access now, I could not access in the past because my trial have expired but Yuxiu Weng  ​ helped me to solve this issue .
Thank you very much , you are so kind
Regards
