Feb 10, 2020 6:49 AM UTC
Re: Finding distance from the model
Thank you @RolandRaytchev . Now its working fine.
But now I have another issue with my experience. What is want is that when the distance between our phone and and our model is less than 0.5 a popup should come to alert the user that it is not safe to come any closer.
For that purpose I used following code:
$scope.trigger = function() {
if (+magnitute(fargs.position[0].toFixed(2),fargs.position[1].toFixed(2),fargs.position[2].toFixed(2)) < 0.5) {
$scope.setWidgetProp('popup-2', 'visible', true)}
But it does not work..
Can you help me recifying this error.
    Feb 10, 2020 10:50 AM UTC
    I will suggest to use some code like this:
    //$scope.setWidgetProp('popup-2', 'visible', true)
     $scope.app.fn.triggerWidgetService("popup-2","showpopup");
    //show popup
    else
    $scope.app.fn.triggerWidgetService("popup-2","hidepopup");
    //if distance large then hide
    So I tested and it worked in preview.
    //show popup
    else
    vivekse1-VisitorAuthor
    Feb 11, 2020 5:34 AM UTC
    Thank you once again @RolandRaytchev for you reply. But even now after applying the code provided by you, it doesn't work.
    Another thing is I am using trial version of vuforia studio and in 3D-Container, I do not have the option of 'extended tracking events'. Therefore I am not able to use this feature completely.
