Mar 29, 2019 2:56 PM UTC
Re: Playing multiple sequences with Hololens
I am also having issue with playing multiple figures/sequences in Hololens. This would be reasonable for service procedures..
Is it still not possible? Any news or workarounds? 🙂
Bojan
    ytellaAnswer
    Apr 30, 2019 12:04 PM UTC
    Hi Bojan,
    Yes, it worked for me. I used the below JS function in Home.js and called it under an Application Event.
    $scope.ChangeSequence = function(seq_name)
    $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - ElbowMotorReplacement.pvi';
    $timeout(function() {
    $scope.$broadcast('app.view["Home"].wdg["model-1"].svc.playAll');
    $scope.$applyAsync()
    , 2000);
    You would have to write separate functions for each sequence and link them in the Application Events as shown above.
    Apr 29, 2019 7:39 PM UTC
    A workaround to play multiple sequences is - extract the .pvi files and upload them separately on to the project. Once uploaded, use the resource path to activate the requested sequence:
    $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - ... .pvi';
    Hope this helps!
    bgračnar10-MarbleAuthor
    Apr 30, 2019 6:09 AM UTC
    Hi ytella,
    I know for sure that this works for mobile experiences.
    I tried this also for hololens but I am not able to play sequence.. did it work for you?
    Under app events and JS for gestures I used: $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/bobcatv43_Low.pvz/l-Creo 3D - Figure 1';
    I also bind this gesture to model with play all but no sucess.
    BR,
    Bojan
    ytella17-PeridotAnswer
    Hi Bojan,
    , 2000);
