Re: ThingWorx Studio 8.0.0 Update
I installed the thingworx viewer for this update. When scanning a thingmark though, the view becomes blank and basically the app is inaccessible and needs to restart. Just checking if there is something wrong I am doing, or if there is an issue.
Vish
Vish,
Is this issue persistent even after the restart? As of now, we can't reproduce or see this issue.
Hi Viswanathan Krishnamurthi​,
Which device are you using? Does the Experience shows on Preview? Try uninstalling the ThingWorx view Application and restart the device and then install the application again to see if it helps.
I have the same Issue , i can't see thingmark once scanned it. What i can see is like a white square and i can't retrieve data on my OnPremise Experience service, i only see static content like Labels and so on. It is not possible that every update or in the device part or on the thingworx studio ide something is broken. i can see this on the application log on my thingworx server in local intranet:
No authType or appKey parameter has been specified for Authentication Scheme: AUTH_THINGWORX_APPKEY
but it is all configured like when it worked
Alberto, would you be able to take a screenshot of/with your mobile device and post it here?
