Jul 16, 2019 6:19 AM UTC
Refresh time ThingWorx data
Hi there,
I included some values of ThingWorx. The check mark for automatic update is set. Is there a possibility to refresh the values more often by making a refresh more often?
Thanks for your help.
Jul 16, 2019 9:19 AM UTC
@mn1  I believe you can check out Auto Refresh widget in ThingWorx. The Auto Refresh widget raises an Event at a user-defined time interval so that you can configure it in such a way that required values get updated based on predefined internal in ThingWorx. Since the automatic update is marked in Studio same updated values should get reflected inside your experiences.
Refer to link for more details about the Auto Refresh widget -http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FMashup_Builder%2FWidgets%2FAutoRefreshWidget.html
mn11-VisitorAuthor
Jul 16, 2019 10:00 AM UTC
Hi @dupatel
Thanks for your answer, but I still have a question.
I do not have a Mashup, because I dont't want to visualise the values in ThingWorx. I just want to visualise them in my AR projekt. So I think I can not add an Auto Refresh Widged. The Data I would like to see in vuforia are values from a PLC, connected with ThingWorx Industiral Connectivety. To have real time values I would like to refresh the values often.
Thanks for help.
Jul 16, 2019 11:29 AM UTC
@mn1 As you are getting data from Kepware I believe there should be a feature to update values in an interval. However, I am not sure so leave it to the group if someone already knows about it & share.
