Jun 24, 2022 10:37 AM UTC
refresh widgets
Hello, I'm filling a list widget with some data and noticed that the widget itself does not show updated data while the code executes. some console.log show that is not a matter of data updating but the widget needs a graphical refresh (e.g. click on the screen) to be refreshed and show correct data. My question is: how to perform a forced refresh of the widget from the source javascript code?
Thank you!
Jun 24, 2022 12:46 PM UTC
depending on widget type could differ. The simple thing is after setting some properties to call:
$scope.$applyAsync()
some time  is better
$scope.setWidgetProp("widgetname","prop", value)
//better as setting the property $scope.view.wdg['widgetname']=value
or call it inside $timeout construct
for some other widgets like charts , possibly we need a extra update method like:
$scope.app.fn.triggerWidgetService("timeSeriesChart-1","updateChart");
so if this mention above does not help, please, provide simples example to reproduce and understand the issue. Thanks
some time  is better
GianVal15-MoonstoneAuthor
Jun 24, 2022 12:55 PM UTC
"$scope.$applyAsync()" correctly worked, Anyway, as usual, I could not find comprehensive documentation about methods, API, etc. It could be very useful
Thank you
