Regarding Vuforia connectivity
Just wanted to learn more about vuforia and how to connect it with thingworx. Is there ay plugin or any other service available using which we can work with thingworx.
Anupriya
Hi Anupriya, you might want to check this thread How to connect vuforia to personal thingworx instance for the update as of now the instance running both ThingWorx and Vuforia are hosted by PTC R&D as mentioned by Ankit Gupta​ in above thread.
Hi Anupriya Agarwal​, Both ThingWorx Studio (Previously called Vuforia Studio) and ThingWorx are already connected. You can call the ThingWorx services and properties in ThingWorx Studio by using the + sign in the right panel ThingWorx Studio.
Just curious, are you part of the Pilot program?
