Sep 24, 2019 11:43 AM UTC
Running experience server without connection to thingworx
Hi..
Is there any way to configure an on premise ES to run, without a connection to the Thingworx server.
I need this to show a light weight demo ( no security concerns ) without installing Thingworx on the laptop from where the demo will be served.
Cheers
dupatelAnswer
Sep 24, 2019 12:29 PM UTC
@SteffenAu2mate  You will need ThingWorx to connect with Experience Service (ES). If you have a trial or some working ThingWorx instance then can update your ES configuration.json to point to the existing TWX instance to be used.
Also, you can check out Studio Trial which can provide quick help. Note, you will require PTC credentials to access Trial.
-Durgesh
dupatel5-Regular MemberAnswer
-Durgesh
