May 6, 2021 12:46 AM UTC
Scan QR Code using Scan Widget & Text Input [3D-Eyeware]
I have trouble in scanning small QR Code when using 3D-Eyeware (Hololens II). The QR Code size is 0.5cm2.
If the QR Code cannot be scanned I would like to have another option which user input text or accept voice as input to text. But I cannot see any function for that kind of input.
Any kind of idea would really appreciated as this scanning function is very crucial in my project.
Many thanks.
May 7, 2021 1:24 AM UTC
NA_nur1-VisitorAuthor
May 10, 2021 6:29 AM UTC
Hi @dsgnrClarK ,
Appreciate your reply and thank you for the reference.
Actually, I just realize the label that need to be scanned is data matrix barcode which is not supported on Hololens device.
I found ZXing library (as link below) that support data matrix scanning.
https://opensource.google/projects/zxing
How can I integrate the library inside Vuforia Studio scanning to use ZXing image processing to get the data matrix barcode value?
Thank you.
Aug 3, 2021 5:04 AM UTC
Does anyone has answer for this ?
i m also looking for the same solution.
