Feb 14, 2019 12:51 PM UTC
scrollbar at mobile device
Hey there,
I have added a label widget with a lot of text. When i view the preview there is shown a scrollbar to scroll up and down the text. If i upload the project, there is no scrollbar at the mobile device. Why is the scrollbar only visible in the preview? What function do i have to add to make the scrollbar visible at the mobile device, too?
mn1Answer
Feb 26, 2019 7:34 AM UTC
Hi @RolandRaytchev
Now I found a solution!
If you look at this page:
https://forums.asp.net/t/2086244.aspx?Scrollbar+visiblelity+don+t+work+correctly+in+mobile+browsers
and add the code to your styles (not in a class) then I can see a scrollbar on android devices
Feb 14, 2019 4:25 PM UTC
Hi @mn1 ,
I know that there is similar issue with a panel  which could be scrolled in  preview and on android but this will not work on IOS. What is your mobile device IOS, Android ...?
mn11-VisitorAuthor
Feb 15, 2019 7:06 AM UTC
My mobile device is android. I have a secound device which is windows.
