Mar 14, 2021 11:45 AM UTC
Sequence does only play after double tap on HoloLens
I am currently working on a project where you can interact with a machine by using buttons to play animations.
I got the animation to play on the HoloLens using following code:
$scope.playSequence=function(name){
$scope.app.loadsequence(name);
$scope.$applyAsync();
console.warn("$scope.app.loadsequence() executed");
$timeout( function() {
console.warn("app.loadsequence() executed");
}, 1000);
$scope.app.loadsequence = function(name)
{ $scope.setWidgetProp('schwader', 'sequence', "app/resources/Uploaded/"+name);
twx.app.fn.triggerWidgetService("schwader", 'playAll');
But I have now the problem that Animation plays in Preview just fine, but on the HoloLens it is needed to tap the button twice in order to play animation.
Is it possible that because the machine is quite large that is taking its time to load in the animation?
sebbenAnswer
Mar 15, 2021 7:52 AM UTC
you can do it like this:
$scope.playSequence = function(pvzName, SequenceName){
$scope.view.wdg["schwader"].sequence = "app/resources/Uploaded/" + pvzName + "/l-Creo%203D%20-%20" + SequenceName + ".pvi";
$scope.$on('sequenceloaded', function(evt, arg1) {
 angular.element(document.getElementById('schwader')).scope().playAll();
sebben14-AlexandriteAnswer
