Oct 28, 2018 12:18 PM UTC
Sequence Voice command works on Mobile device but not on IPAD
I have this code that works on mobile device(Iphone) but not on Ipad. Any idea why?
var labelId = "label-1";
$scope.$on('newStep', function(evt, arg)
$scope.setWidgetProp( labelId, "text", arg);
var labelText = $scope.view.wdg['label-1'].text;
var InstructText = labelText.substr(labelText.indexOf(")") + 1);
$scope.setWidgetProp( "label-1", "text", InstructText);
var spokenText = $scope.view.wdg["label-1"].text;
var msg = new SpeechSynthesisUtterance(spokenText)
window.speechSynthesis.speak(msg);
Avinash
Oct 29, 2018 7:15 AM UTC
Hi Avinash,
I couldn't find any mistakes in your code. You could check the settings of your iPad. Vuforia View should have the same permissions as on your iPhone. Make sure, that all necessary volumes are turned on. Check, if the newest version is installed.
greetings
whity
